Spoiler removal - Impreza hatchback
How to in photo's
remove top centre panel of boot trim
pin locations
Then remove each side trim and disconnect the rear light cable and rear window spray pipe
again pin location
Remove the four 12mm bolts and use a tool to pop the two accessible pins (I used pliers)
flex the spoiler upwards to free the centre pin there is enough free pipe and cable to do this easily
pull the rubber grommet free and remove spoiler
spoiler view with all pins and studs - much easier to access brake light now
car without spoiler
to refit line up spoiler and feed cable and pipe through hole and fit grommet then push excess external cable and pipe into spoiler recess
unit will drop into place retained by the 3 pins, refit nuts and panels side first centre last
Nicely done Jay.
  • 11 years later...
Hey Guys, So I lost the nuts from the two sides, they’ve gone in the boot, how would I go about getting them?
