Forester advice
Hi. I'm new to subaru's, have forester X and keen to furnish with some nice oil and some fresh boots. Keen to get some advice. 16" standard alloys, mostly road driving... No real criteria, but prefer good MPG and low road noise.
Oil, any advice welcome.
Although I'm not desperate for it as more than happy with standard car.. Is it possible to easily add turbo? Sorry, bit naive when it comes to things like that.
Thanks.
Kiwi
Hello :-)
Welcome to the club,
Tyres seem to be a bit of a trade off between mpg/noise don't know weather thats due to being a reinforced tyre or not but i've not managed to find one that does both according to the ratings.
To be fair i have two different brands on each axle both 'intermediate' price range which were on the car when i bought her, the noise isn't an issue as i find the sound proofing in the forester cabin to be excelent, so when i go for new sets it will be more towards the mpg side of things, tyre wear is good too.
Oil i'd use the best you can find, try opie oils (trader on here) good advice and competitive price always has discounts etc.
Mine runs on 10-40 semi synth, being slightly newer yours may be different i'd check the manual,
As for adding a turbo you'd be better off buying a turbod car. As the amount of work involved is alot. just about everything on the engine needs to be replaced or added to.
I'm sure youll be more than happy with your foz and if you do decide to start 'adding' bits 90% of the impreza bits of the same year fit.
I think Stanton500 covered the tyres well enough so no need to add anything to that :)
For the Oils either speak with Tim on here at Opioils or go on the website and can do a check for everything you need. And an added Bonus get discount for being a club member :)
http://www.opieoils.co.uk/
Hi. Thank you kindly for advice. Will check out tyres. Someone recently mentioned Hankook ( sp?). Has anyone had any experience with these. Cheers.
I like Hankook but loving the Falkens at the minute but I have noticed road noise is increased with them but they are solid great all round tyre.
