Tappets?
Heya guys.
I have an impreza sport. I think the tappets are !Removed!. How easy is this to sort? It's noisy and !Removed! embarrassing. Thanks in advance xx
Hi Mel You sure it's the tappets ? the cambelt tensioner sounds the same
skip to 4 minutes 30 seconds can hear it
Hi Mel, any chance you could do a video and post it as that may help with the diagnosis.
is the noise constant or does it change with the revs, does it change when the car warms up? Has this just happened or has it got progressively worse over time?
Heya yeh It sounds a bit like that video actually. But it stops once the car has warmed up and better after higher revs.
Yeh I will try to get a video either tonight or tomorrow. Thanks xx
Thats will be great Mel hopefully be able to get a better idea, not always the case but worth a shot. :)
Okay so I have a video. Car not overly doing it . But how do I add a video? Xx
Will have to upload it to Youtube 1st then link it here :)
when was the last time it was serviced, and whats the current mileage ? has it had a rebuild and is it down on power ?, cause the video is short in length its hard to tell, but could be just very noisy tappets which classics are known for or worst case it could be the crank, and it got noisy just as the revs where dropping.
Service was about 4/5 months ago. It's literally big standard. It's only done just over 80,000 miles. I will try and get another video up a bit longer. X
I don't think it's the tappets. I'm going to guess it's what I said first doesn't sound as bad as the bigends.
Oki thanks. Good to have an idea before I imagine if get ripped off lol. You guys are helpful. Thanks xx
Well we try our best and wouldn't want to see any member get ripped off here. So thank us if we're right :D X
