2008- STi rear RED OVERLAYS
these are Premiumautostyle rear red overlays for the 2008- sti hatch, I've imported a few sets and have a couple of sets left over.
they are £30 including P&P (sign for delivery) PayPal will be fine. these will be sent out in a a3 size hard backed envelope.
a how to fit guide is on youtube, search for premiumautostyle rear overlay fitting
  • Replies 68
  • Views 8.2k
  • Scooby Pete
    Scooby Pete
    Got one side done. So much easier with a hair dryer. Took about an 1 1/2 a side. Much easier using a hair dryer and even being in the sun helped to keep the vinyl supple. Before. After. Yes it do
  • Ok cool, how much are they going to be please? Better take 2 sets I'm bound to balls it up lol
  • salsa-king
    salsa-king
    I've got some more sets shipped   put them on ebay,   buy one set, here they are http://www.ebay.co.uk/itm/Subaru-STi-Hatch-2008-on-rear-light-red-overlays-ONE-set-/291156774956?pt=UK_CarsParts_V
Three sets left now
Sent from my ST23i using Tapatalk
Looks good a lot of work but worth the time :)
Two sets left now
Pete,
the set I'm sending you today have more 'bleed' on them for the side clusters, just check they look the same red as what you have, or re do all with this new set.
did you fit one and mess up, or had you already done them and messed up on one part of it?
I fitted the smaller n/s reverse and split the larger n/s one as I got halfway through fitting it. Didn't even try the o/s after that.
Will be using a hair dryer rather than heat gun this time.
yep I know, :)
I didn't have a problem with mine as it stretches as you give it a bit of heat. But after what was said I did ask Dan to give some more bleed to it and he added about an inch.
Can you work with it easier?
a quick blast of heat!!!
are you at Prodrive next week?
come find me then
:) show me your overlays ;)
Before.
81742511-C716-4602-B1AA-DB3484F5231F_zps
After. Yes it does need a clean
863FD647-CA8E-4C7F-A004-8893E04708E6_zps
0C8F0BF9-B441-4F73-A1D7-122A98444F7B_zps
Pete, they look really good. How did you manage wrapping over the top edge? I struggled.. not 100% happy how I did mine.. it was 20 past midnight, so fed up and tired... took me all evening and two sets of over lays :(
see you sunday?
see you sunday?
What I did was get the main part done over the bumps and curves and I left about an inch unstuck from the edge of the light.
Then in small sections (about an hands width) I heated and stretched it out towards the edges and used the squeegee to push out towards the edge and fold the vinyl down behind the light. Last thing I did was to give the whole thing a blow over with the hair dryer which seemed to shrink it back a bit for a really good fit.
The only place I really had trouble with was the bottom corner of the large light above the wheel arch. Not really happy that I got enough bleed tucked behind it. I was quite lucky in that I was able to get most of the vinyl tucked down behind the lights and didn't need to cut too much off. Also where the soap solution dried on the inside of the vinyl has left a cple of smears on the inside.
Weirdly I found the 1st side easier to do than the 2nd one and also easier than the 1st time I tired a few months ago.
Spot on job mate look loads better.
Very tempted to get a set of these over lays for my car Salsa, You got any pictures of yours buddy? as you're scoobie is also white :)
Does look good on the white.
it does , should have been standard
