car tick over like little shakey
ok here we go .....my son done a compression test on my car 1994 import turbo then my car developed problem he said he turned car over during comp test and car started coil pack may have been damaged changed and replaced then no problem there and new cam belt that is now done and new hydrolic tensinor  ...
car does  start but seems under power and strong smell of fuel car was fine before he wanted to give new tool a go on the car now i have problem it has little power on tick over i have not driven it at all what can i do
my son said yeah jay all four are firing
ok - smell of fuel could mean its running rich for some reason - are there any codes logged on the ecu - thinking possibly duff sensor
ok going to do ecu code check in 2 min buddy be back 10 minutes jay thank you for your help bud
ok jay the code i got are 31/45/24  the check would be off i dont want to damage engine on dynamic mode you have to rev the car or drive it and i dont so this is why i done it why it was off
31 was=
Throttle position (TP) sensor - signal malfunction Wiring, TP sensor, ECM
45 was =
Manifold absolute pressure (MAP) sensor/MAP sensor control valve - circuit malfunction Wiring, MAP sensor, ECM
24 =Idle air control (IAC) valve - circuit malfunctionWiring, IAC valve, ECM
do you think they are my problem i changed tp recently thinking change or check other two what you thinking
yeah had problem with maf recently changed it for another not checked it yet but can tomorow and did i mention the car vibrate on tick over
could i have damaged valve ? if i have can they be replaced eaSy or am i jumping the gun
check the others - scoobies are lumpy on idle anyway but if this is something you are not familiar with its looking like something different, I believe the compression test is a red herring in itself unless something else has been disturbed putting the tool in place and removal etc.
Try disconnecting the maf as its an easy check although as you have changed it recently it is probably not the cause.
when doing the compression test all valves - throttle etc should be open to get the air in when cranking the engine - has anything been disconnected in order to make that happen?
i will get my boy to look tonite....jay     im thinking itnot firing on all four cylinders now i dont no about mechanical stuff but to me it could be that as couple days ago i was playing with another scooby on the A road and got like a red line feeling pulling away in low gears like a flat spot no more power to give until i changed gear ( i was driving hardish ) and not much power over 100mph does this add up to my feeling of cylinder not firing ? car has been running well untill i gave it a little welly the other day lol
i dont no but would it be idea to have it port and polished when or if i need it removed ? would that make any diffrence to car at all ?
sorry for all these Qs buddy but i dont no what to try  after the sensors  maybe atempt to remove block and see ...not bad for a beginer lol
did find damaged coil pack now changed but still no diffrent  .....i wont let this beat me
hmmm - it may something as simple as an air leak - did this all start after you gave it some beans or after the compression test? As you may have got a loose connection or a new split appeared.
porting and polishing heads different story - its great if you are going the full del monte like Savage and that sleeper he has put together - it works well in conjunction with other mods but doesnt necessarily have to be done just because the heads are off
ok jay i will check all my hoses for leaks im using blue silicone ones  are they known to leak would you no ?  and will spend an hour looking if anything disconnected  thank you buddy
it all begun after the compression test fine before i have not driven it since going for breakfast now then going over hole engine bay
will report back later....with good news fingers crossed as it hurts driving her corsa .....
Seeing as you've got a few codes up and all the sensors that are giving the codes are on the inlet manifold .
id check your engine earth's and the two grey engine loom plugs (one near the battery one near the maff) are free from corrosion /conected
Check you haven't knocked off /split any vacuum pipes and do a ecu reset
thankyou   i will be checking all today every bit of info you guys give me will be big help thank you
ok all air pipes checked no leaks ...but my son removed  a pipe from front mount intercooler and car run fine ...so there seems to be a problem i added this fmic about 2 months ago could this be my problem my car has not been mapped  should i return to the top mount intercooler untill i get a map....
just curious jay but wy could a front mount intercooler cause this to happen ......trying to find original top mount intercooler to go for test drive
Only thing I can think was the pipe was some how starving it of air  :wacko: and I can't see why it would need to be mapped.
dont worry about mapping just yet, sounds like you have a blockage - there isn't a piece of shipping packaging still in the FMIC is there?
!Removed! hell yeah there is jay large peice plastic  now removed can not believe that..... ok car running much better shaking now gone but little weak on power still think it could be a sensor going to do another ecu code check
i cant believe that jay ......ok took car for tesT LOT BETTER BUT HAVING TROUBLE WITH NEW BELT ONE TOOTH OUT LOsING PATIENCE WITH IT ANYONE NO MOBILE MECHANIC IM IN CANTERBURY KENT
BELT ON COVERs ARE OF JUsT CANT LINE ONE END UP OTHER END FINE ..JUsT ONE TOOTH OUT AsOON As ONE END LINEs UP OTHER END OUT    AAAAAHHHHHHHHH
