hey all from kent
Hello all im nick this is my first subaru my subaru is a yellow 2.0 non turbo
im 22 years old and I want to learn alot about them atm I have one trouble its the abs fault code was 35 and 56 anyone know what needs to be replaced and a rough price??
Nick
Hello mate welcome to S.O.C
Not sure of the codes from the top of my head but I would check your pads have some meat left on them and take the abs sensors off and give the contacts a clean.
Hi mate and welcome to the site :)
Photos to be taken thursday and gambit cheers mate il give that ago
No problem look forward to the pictures and hope it sorts the problem out. I don't think it will be anything big to fix :) normally just a clean of the sensors and a wiggle sorts it most of the time.
Didnt work this time :( dis conned battery all night hoping after cleaned them tht ecu resets lool
found this info through Ebay (believe it or not) not sure how useful it will be but better to share info than keep it to myself ;)
Fault codes
1111      No codes stored
11        Crankshaft position sensor (Don't confuse with above, usually when the crankshaft sensor if dodgy the thing won't start anyway)
12       Starter switch faulty
13       Camshaft position sensor
14       Injector no.1
15       Injector no.2
16       Injector no.3
17       Injector (You guessed it!) No.4
21       Engine temp sensor
22       Knock sensor
23       Mass air flow sensor
24       Idle air control sensor (usually accompanied by running too fast/slow)
31       Throttle position sensor
32       O2 sensor
33       Vehicle speed sensor
35       Emissions canister purge valve
38       Torque control signal (Automatics)
42       Closed throttle position
44       Turbo wastegate regulator malfunction
45       MAP sensor
49       CO adjustment resistor for older cars not fitted with cats
51       Neutral switch (Manual gearbox)
lol gambit holding out on us are ya? :P
I saw this on his other thread and none of the codes for ECU relate to the abs. I did a bit of golfing and came up with some abs codes but they didn't have some of the codes nich had posted.
After further reading It's not a full list and no one seems to have a complete list.
Seems the only real way is to use the proper diagnostics tool from Subaru to find out what's going on.
Here are the codes hope they help.
ABS DTC list
11 – Start Code, DTC is shown after start code, Only start code is shown in normal condition
Abnormal ABS sensor, open circuit or voltage too high
21 – front right ABS sensor
23 – front left ABS sensor
25 – rear right ABS sensor
27 – rear left ABS sensor
Abnormal ABS sensor, abnormal ABS sensor signal
22 – front right ABS sensor
24 – front left ABS sensor
26 – rear right ABS sensor
28 – rear left ABS sensor
29 – any one of four
Abnormal solenoid valve circuits in ABS control module and hydraulic unit
31 – Front right inlet valve
32 – Front right outlet valve
33 – Front left inlet valve
34 – Front left outlet valve
35 – Rear right inlet valve
36 – Rear right outlet valve
37 – Rear left inlet valve
38 – Rear left outlet valve
41 – Abnormal ABS control module
42 – Source voltage is abnormal
44 – A combination of AT control abnormal
51 – Abnormal valve relay
52 – Abnormal motor and/or motor relay
54 – Abnormal stop light switch
56 – Abnormal G sensor output voltage
