Advice on Hard wiring a Roadhawk HD Dashcam.
I have a Roadhawk HD dash camera on my other vehicle.
Rather than use the Cigarette lighter cord I hard wired it into the fuse box ( using the Roadhawk hard wire kit ).
I wired it into the fuse box into a fuse which is only live once the ignition is turned on.
Could have wired it up to a permanent live but didn't want to drain the battery due to constant usage.
I currently use the Roadhawk in the forester but connected to the lighter socket behind the hand brake, ( the front lighter isn't working for some reason ). :(
I have received another Hard Wire kit  and suction mount from Roadhawk which I want to install into my Forester 2.5XT  so I can just move the dash cam between vehicles and plug it in.
Could someone please advise on which fuse or line I should join into which will only be live once the ignition is turned on, preferably into the fuse box in the dashboard area if possible
Thank You
I've got a gauge wired into some stuff under the dash so i'll take a look for you tomorrow during daylight :-D
If you don't want to chop the loom could use one of these piggy back fused spur, anyone of the fuses will be live when on. Mines attached to a perm live fuse though.
For the ignition live wire i found a spare green wire under the dash that had a spade connector on it it was gathered up and had never been used, for an accessory on options list maybe ?
Just chopped it and wired into that.
Finally do you have the front fogs fitted with the 3 switches above the fuse box on the dash ? Just wire it into the live side.
Anyway hope this helps :-)
