Hi all
I'm new to all this forum stuff so take it easy on me.
Just bought my first scoob after saving for several years, absolutely loving it but like most cars it has its issues. I'm fairly competent with my tools and live getting my hands dirty.
I own a jdm wrx completely standard on a 1995.
Got a couple issues that I'm nearly at the end of my teather with.
If someone could point me in the right direction as where to find the info needed that would be much appreciated.
Also is there any specialist around my area I live in Suffolk
hi and welcome to the site mate if you tell us what sort of "issues" you've got im sure someone can either help you out on here or point you in the right direction
look forward to seeing some photo's of the scooby :D
Hi mate welcome to S.O.C
Please feel free to have a look around the forum if you haven't yet, and join in on the threads all friendly bunch on here :) And 2nd pictures I like pictures just the same way I like my books :)
Right
Basically Im getting really bad and temperamental flat spots
As soon as I got the car I gave it a full service,oil,filters,plug's,belts
I've checked for obvious air leak's
Removed and cleaned the boost solinoid and the waste gate actuator
replaced the maf
still no joy.
now if I gently apply the power it boosts fine and smooth but as soon as I plant it I get really bad flat spots.
sometimes There that bad the whole car dies.
I'm getting to the point I don't know what else to try might even have to take to a garage and I hate being defeated.
I was thinking maybe tps but not sure.
No eml or cel lights
unless you manually have to check
Hi and welcome.
Ignore the CEL. Check for codes manually. It's the only way to be sure and sometimes, the CEL blinks for a fraction of a second and it's easy to miss it. Only yesterday I had a running issue with my Legacy and no CEL. Checked for codes and got 23. (MAF).
Always worth checking codes first. It could be a number of things from your description.
hi mate
welcome to the club
check for codes manually, it will probably be something minor that has been overlooked
Ok next question shall I use my dino tool or do it with the standard leads
Ok so I have run the car through the factory dino and it's come back clear no codes !!
Could be a dodgey coil pack?
Take them off remove the rubber sleeve and check for cracks and signs of damage. My classic had been running bad and I tried all the usual stuff. It was coil packs in the end.
Yeah I did notice when I changed the plugs (pig of a job)
That one of them was split but didn't think that would effect it.
