Came to use the lights this morning to find all lights work except front side lights at first position yet rear lamps are on.
impreza 1998 sport 2.0 litre non turbo
before i look any further anyone know what fuse it might be or offer an explanation including maybe both front side lights blown
appreciated
reckon ill get two new bulbs in the morning
fuses ok rear lights ok
cant be much else can it
Ground issue ? have you tried the bulbs in a different way ?
I would check the front bulbs are earthing correctly mate I had a similar problem a few years ago but it was on the back and was making my brake lights stay on when I turned my lights on one of the bulbs was the wrong fitment. So I would check all the bulbs in the front are the correct fitment.
i had a blown n/s side light till i changed the bulbs (both sides) but the light still only intermittently works will check earth tomorrow. is it both sides not working or just the one? coz if 1 side works then i would suggest using the working bulb to test the connection.
