Rear hub lateral bolt
Hi guys, having trouble removing the lateral bolt on my rear hub (2001 2.0 awd sport) any  tips or tricks? I am guessing this might be quite common, needing to remove it to replace rear wheel baring, will i need new bushes? or what do you think guys?
You may not need new bushes but if you suspect you do, now is the time to do it whilst its all in bits. To get the bolt out is a pain. I would suggest loads of WD40 all over it and left to soak in overnight.
as tlag said soak it in WD40 i left mine for about an hour then just brute strength get a spanner on one end and socket on the other otherwise it'll just keep spinning
I have spammed with WD40, but mine will not  even spin haha, its welded solid!
Do you have a long breaker bar or drive bar to het on it. Maybe something like plus gas is the next option if wd40 and a longer bar won't work
I have used plus gas in the passed, great stuff but hard to get hold of!
remember before you start banging with a sledge hammer, using extended breaker bar etc etc make sure to secure your vehicle as safety first!
and as Eric the car guy states; stay dirty :lol:
Would I not just break off the head of the bolt with a long bar?
Depends on how heavy handed you are, if you just go jumping up and down then maybe. Of it's had a good soak in some wd40 or similar than applying gentle force on it should just ease it free. If all else fails have a drill handy
i think i may try find some stainless bolts to replace them with and use plenty of copper grease! haha
