Fuel lines
Still got my inlet in shed trying to think what else can do to it while it's off ,seen a few with braided parallel fuel lines is this worth wile and easy enough to do and what's the gains and what's involved in doing it thanks
Probably not worth the extra £200 imo , unless your aiming over 400hp or running higher than standard fuel pressure .
You can mod the oe set up to parallel's cheaper but, I didn't fancy doing that it in case it leaked cos I didn't seal something properly .
the idea is to reduce the chance of fuel starvation to the last injector in the oe "series" fuel rail set up under high load .
converting them to parallel's gives the injectors a more even pressure through out .
If I did it I'd probably buy new top feed rails and good quality fittings , like tlag is doing
Just thought it would look better didn't think it would be that much forgot about changeing rails how do u go about modding standard rails
