Classic rear seat removal
Hi guys, need to change my rear socks, how exactly do I remove my rear seats in my classic Impreza saloon?
Remove the two bolts on front of bench (where your calves would be if sitting down on seat) then from the middle of the back push down on the seat and it will unclog from the back support.
Then there are 3 bolts that bolt into where the bench part was remove these and lft the back support up and away.
Now carefully remove the parcel shelf which is held in with plastic clips, this gives you acces to the top mounts of the rear suspension.
