Posted
Can someone let me know if there any 'hidden' screws which need to be removed in order to remove the drivers door card.
Posted
Pretty much the same for alo models.
One screw in the door pull then it will just pop off.
Start at the bottom corner and firmly tugg the door card towards you, then work around the bottom and sides pulling the door card away from the door, when it's loose lift it up and away from the door.
Posted
Think I did a thread on this but here are photos showing locations of stuff
Register a new account
Sign in
