GB270 rear end rattling
Evening, I have recently purchased a 07 GB270. Past few days i have heard a rattling coming from the rear of the car, I thought the spoiler may be loose but is solid on the boot, it only starts when i take off and never hear it when at speed. Clueless ??? me too. I dunno if its the rear diff? the suspension or the wheel bearing, had a look under today but no visible signs. Any one had this problem before on the GB270 or even on STI. Would like to find out what it is before taking to garage. Cheers w333tag
Could try checking
Exhaust mounts (give it a shake)
Rear droplinks (wear/ play in the bushes)
and rear shocks (prone to failure on the blobeye I think)
Play in the rear wheels
Does it do it over bumps or corners as well ?
exhaust mounts are fine, when pulling away its as if its stuck, then go over a bump and sounds wobbly if you know what i mean
and yes to the bumps and corners
heat shields for the backbox/mid box on the rear are a problem, check the struts themselves as they could be worn.
Was on about this with nick and dave the other day, they reckon its just drivetrain noise his sti does it and he's had it up on ramps to find out and can't see anything that would cause it.
Can't remeber for the life of me exactly what he said he thought it was but I'm sure he'll be a lon in a bit
Sounds like your rear shocks have dried up which is fairly common, they just need taking off and greasing again then the noise should dissapear.
Thanks for the comments, drop links needed replace and it is the pistons in the rear shocks are sticking. The car is coming on well with bov, subaru flaps and blitz exhaust. Looking and sounding the part :)
