Custom hand brake (parking brake) lever
I've grown to like my Subaru Forester XLN apart from driver comfort, so I've been thinking of buying a newer model.
The only problem is, on every other newer Forester I have seen the parking brake handle is canted to the right.  I am a very big fellow so I find this position pushes into my left thigh.
Is there any way to get this changed?  Anyone seen an alternative that doesn't do this?
Anyone know a custom parts maker who might do something here?
I'm wondering if the reason for this strange right facing lever is a cosmetic one, or if its needed for some technical reason, e.g.: the travel of the gear lever would tend to get in the way of the parking brake handle.
Ive tried having a look to no Avail, maybe go into your local Subaru too see if it is needed to be like that, i would say you could change it for a smaller handle, it should twist or screw off.
Thanks, the dealer wasn't any help when I asked. Just one of those things they don't 'get'
It might have to be a Discovery 3 for me, but they are a bit wide for the roads around here.
I find it strange that it would be in such a place, best person to ask would be someone like stanton or the other forester lads.
Hello, I hear my ears burning !
Can you take a picture of the offending handle ?
Do you have a low ratio box lever in the centre console as well as the usual gubbins ?
It does seem strange that it's offset surely that would cause injury in the event of an accident, mines an older model but I have at least 4" between the gear leaver left in reverse and the top of the handbrake.
Have thought about replacing the seat ? Plenty of comfy 2nd hand impreza forester & legacy ones around that may enable you to sit an inch or so higher and not get stabbed in the leg
What you could do - does require a bit of work though - is fit a brake lock lever - this puts pressure to the rear brakes via the hydraulic lines, they are smaller than the handbrake lever and could be mounted in a place more suitable
http://www.mico.com/products/brake-actuation/brake-locks
PS. link is to show examples - I know you can get them in the UK
