What engine?
Hi all, I've recently worked out that my engine isn't the one that came on the car, but I can't work out what engine it is,
If has stamped on it
Ej20
The long number in the back where it meet the gearbox is 109528110575
And the number on the block by the starter motor is B158555
Anyone know what these mean??
I've had a quick look for engine codes and can't seem to find much info to help .seems to be lots of info on vehicle model codes but not much on engine side of things.
I know my cdb's original engine type was a "ej20G" as it was on the sti I'd plate it came out of .
But my engine has ej20 stamped on it too , so I think that's possibly a generic code across the 2ltr range .
Being a uk car have you crossed referenced your numbers with log book engine number ?
Did you find clive attowes number in the end ?
I've tried but it's not coming up with anything all I have on the log book is the chassis number and that's all alright.
Yh I got his number and I'm gonna give him a call tomorrow
Cheers buddy
if its closed deck it will have an etching mark on the front near to the alternator, if it doesnt have this it isnt a CDB
Looks like this
Yes I have that. Wat does it mean? Cheers guys
Cdb's have more metal around the bores making them stronger (with the right internals)
If yours has got the ## marks behind the crank sensor plug then it's definitely a earlier engine .
As they were only fitted from 93 to 95
Any ideas if this is all right?
How do I post pics
