Replacing drop links
Hi guys, has anyone replaced the front arb drop links on a bugeye?
Easy job or not?
Cheers
Very easy & new drop links from BluePrint or Solid Ace are not expensive .
above brands are about £20 each & you should be able get them for that if shop around local motorfactors or try Amazon, they very good quality parts, you can get cheaper such as First Line at about £13 but won't last as long & the quality drop can be seen & felt during fitting.
2 nuts on each link, best giving squirt of penetrating oil before doing job but generally no real hassle. If nuts & rod a real corroded mess then either need split the nuts off or carefully cut at base of nut & through threaded rod.
Link below of BluePrint replacement & has pic of part in question ...
http://www.yoyopart.com/oem/1977047/blueprint-ads78504.html
Is it just a matter of removing old ones and slotting new ones straight in, or will there be any pressure/ load from Arb or the wishbone?
If car sitting level no, if you jacked one side up then yes.
If you need lift car to do job then lift both sides same.
You may find just a little load when remove first joint but that nothing that can not be controlled & pulled in line by hand for refitting.
Just about to do mine, anyone know the correct torque valuse for the nuts ?
On your SF with the figure 8 plastic/duralon drop links the bolt torque is 24ft/lb on my online data manual.
Cheers, what any idea what that is in newton meters, don't have a torque rench that does foot lbs ? Gone for some uprated polly ones [emoji16] hopefully that dreadful clunking will dissappear
32-33 N*m
Polly ones can be good but some have habit of squeaking
Final torque of nuts should be done with vehicle sat level & under its own weight.
Thanks well whoever put them on last time obviously murdered them up so out with the penetrating spray for a good soak and a cup of tea
If you mean clunking when accelerating or slowing down in my case it was rear one.
Deffo the front at low speeds on lock, can't be the struts or tops as all new. The rears are getting some after Christmas
Drop links delivered this morning. A quick wire brushing a spray of wd40, both sides changed in 30 mins
Didn't have to jack it up or remove wheels.
RESULT
Oh, and no more clunking
[emoji16] I did my fronts Sunday just a bit of an issue with freeing them off as were a bit seized on one side, just ordered a set of whiteline rear links today
