Single Mass Flywheel Conversion?
May just be because you've changed and it's a bit stiffer more nvh into the cabin. Do you start with clutch down ?
no, i tend to start in neutral. Should I try pushing the clutch in?
Yeah I always do, I think it takes the load off the 'box or something, some manufacturers make you put the clutch in before the car will start. Try it and let us know if the noise is any better or worse
Ive always started my car with the clutch pressed down.I think that's just habit though lol
