From TD04 to TD05 do I need to change anything? :P
nope, I dont fit those cheapo boost controller things
  • Replies 65
  • Views 30.5k
    last year I did 4 dyno sessions in 2 different scoobs [emoji5] even if I've not had anything fitted I like it to go on rollers to make sure she's running rite at some point every year anyways .£ 500 f
  • I have no idea Yet lol
  • It will work i know people have done it and work fine more power then the td04. if you are remapping it bigger injector will be required to compensate for more air forced into the engine
So you was running factory turbo pressure.Is that 0.9 bar
mines 1.2 mate
So your at 1.2 bar and that is factory .That must be making some power then lol.  Im on 215bhp on std boost 0.7bar.
thats just the set up of a SP unit! there are a few standard Y7 ecus for v5-6 which have different map settings one has a more aggressive map than the others
I have a Y7 ecu as well sat in a box lol.I might have it flashed  now lol but saying that im making the same figure as the uk 2000 model with out the boost
if its a Ae8000 thats the more aggressive one i think
Oh im gonna look at mine now.Ive just phoned a company who is down the road and he reckons he may be able to flash it
Bumer mine is an A18-000
Oh and my Td05 is here
That might be it mate , I can't remember the exact code but quick Google will tell you
I will google this now Matt.Is yours a W reg and are you yourself on a Y7 ecu
Mines a v , I got a sp ecu
Tho I got a y7 somewhere as a back up
Whats the back up for lol
I have no idea
Yet lol
I guess if it fails, your engine is going to notice it first xD
I thought id better update this thread.Ive removed my Td04  to fit my Td05 and the water pipes and the banjo bolts are larger on the Td05 so the Td04 water pipes wont fit.Luckily ive a mate with a brand new set of Td05-06 pipes so there getting dropped off tonight.
Not heard of that issue !
Neither had I till I compared them both.Just thought I share the information for anyone in the future doing this conversion
Thanks for sharing that! :D
Here is a picture of the td05 and 04 side by side.The Td05 is on the right
And here is the exhaust ports I hope this may help someone
Td04
Td05
As you can see the exhaust on the Td05 is huge compared to the Td04
If the water pipe hits can't u just notch a few mm out the housing ?
The bolt holes are bigger on the td05.I will stick a picture up in a moment
Hi dos anyone no if you do a engine transplant if a need to change anything apart from ovs stuff thanks
