Tmic upgrade
What is a good tmic upgrade? Any good ones
Qhat you looking for ? Yours should be good for 350bhp all day
The fins on it look look like they have bin fingerd :) so I thort I might just get another one an upgrade it at the same time
Haha fair do's the standard ones are really easy to bend. Have Google aftermarket coolers there's loads around depends what your budget is
The secret version 7 jdm sti tmic is the biggest they made :-) bigger than normal newage sti tmic,s
  • 2 years later...
Hi guys looking for some advice. Does anybody know if a wrx v8 tmic will fit on a v1 wrx? If so is there any messing about or will it just fit straight on? Thanks for any advice
Newage coolers fit on classics but require the intercooler brackets from the new age you will have to cut down the brake fluid cylinder and depending if your turbo is top entry or not may need some modifications.
I'll try an dig out the link
That's great thanks for the advice  👌
Na the only uprated tmic that will fit a v1 is made by "arc" and they're pretty rare now days.
As the v1/v2 phase 1 inlet and throttle body sit a lot closer to the bulkhead and make it almost impossible to fit any other oe subaru tmic
