So ok guys I need your help. I opened the bonnet today as I have an oil leak and was poking around and I noticed what looks to me like the blow off valve leaking oil. Is this normal? If not how do I fix it?
Cheers.
I will post pics shortly.
I'm a bit unfamiliar with the legacy set up but the factory recirculation valve is normally located on the passenger's side of the tmic and aftermarket blow off valves are normally fitted just before the throttle body .
The area in the pic is very close to the turbo and there's only a few places that have oil running through them (on a single turbo set up) so maybe have a look at these to see if you can find the issue .
If the turbo seals have gone it normally pushes oil into the inlet tract and you'd get oil in the tmic /throttle body and blue smoke from the exhaust tail pipe .
The oil feed to the turbo is connected via a banjo bolt which might be leaking onto the outside of the turbo .
The oil drain pipe (from the underside of the turbo to the head) this pipe gets a bit brittle and somtimes weaps/splits .
The oil drain itself can get blocked and cause back pressure on any of the above causing a leak in that area
Hopefully it's a easy fix for you fella , keep us posted
Ah cheers. I'll take the top mount intercooler off tomorrow and take a closer look while the sun's shining.
Don't panic, that all looks very normal. Oil residue/vapour finds its way out over the years. If you took the IC off you will find a small amount of oil running around inside it. It's not ideal but it's not anything to panic about. It might simply be a pipe clip not as tight as it was when it left the factory or something similar.
The stuff you have seen has built up over time, it's not suddenly appeared.
Well I'm not gonna lie I did have a slight nugget in my shorts as I have used around 5 liters of oil in a week.
Possibly oil feed or return leaking
Ye it's quite bad I'm gonna put it on ramps today and investigate.
fingers crossed it will be a hole in your oil filter or something cheap & easy
I hope so although I did an oil change last week thinking maybe it was the filter seal but it wasn't that. I'll do some digging and update later.
So i finally found the oil leak!!! What pipe is it. And where can I get one. post-4069-143127214608_thumb.jpg
No idea ! Where the hell was it attached to ?must be leggy specific ?
Was attached to the left hand side of the top mount intercooler. Turbo to intercooler
That's what I was thinking but didn't know who would be best. Cheers mate I'll take a look.
Viper have a kit to replace both IC to turbo hoses and the IC to throttle bidy
I was skeptical of them at 1st as they were half the price of everywhere else but after receiving the hoses they are just as good as Samco etc.
Was on the phone to them and they said they make big volumes hence passing the savings onto the customer, plus they usually have stock so no waiting 8 weeks for them to be made
Cheers guys I'll give them a ring tomorrow
Hey sam. How you doing mate? I'm on the website now they're £50 for the 3. I gotta get tyres, break pads and a drive shaft gator tomorrow so I'll have to see how my bank balance is after. I've done a temporary fix for now and seems to be holding
Could be an opportunity to put a newer gen in or an STI lump
I've found a reasonably priced direct replacement that I can put in, just to get me back on the road... In the mean time the other bag of spanners is going to be pulled apart and tinkered with.
I did say I wanted a project... I just didn't expect it so soon. Or to be an engine rebuild!
How's your car going anyway? Did you get that other legacy in the end?
No time like the present ha ha. No I didn't get it in the end. I still wanna do that front end swap but trying to save my pennies to get a respray at the same time so it's all done at once.
