Self levelling head lights
The headlights on my 57 plate Outback are set to high is there a manual way of resetting them thanks
There should either be a manual over ride on the ballast, or have you tried removing the fuse and seeing if they reset ?
I assume you mean the dipped headlights are aimed too high? Any work done which might explain this, if it's a recent development? Have they always been like this? Fresh bulbs put in recently? If so, they may not be seated properly and you'll have to remove the cover (grey plastic behind each h/l fitting) and check. If you've done this and the bulbs are sitting fine, there are adjustment screws on each headlight housing. Let us know if you need directions on finding these screws (assuming you've checked the bulbs, and there's no physical damage).
There's a shutter flap in the HID headlights on Gen IVs that should move up and down when you select main beam. Could be that it's stuck in the main beam position. (someone had this problem over on UKLegacy the other week).
Thanks for the advice had my local garage have a look at it,seems the control switch on the rear axle needs replacing.
Do you have this wheel to scroll?
If so, the beam can be adjusted up or down
All cars have it. It is to an just headlights up or down depending how heavy your boot is. Ie 5 people +loads of luggage in boot would be number 5 . 0 is when car is lightly loaded. Normally you should be driving on 0.
Have I misunderstood the problem? Sorry
  • 3 months later...
He may not have this wheel.  Xenon head lights by law are required to have automatic adjustment to prevent a heavy car blinding on coming road users (due to the extra brightness of the Xenons).
During MOT the car should be adjusted only part of the test where a tester can change any part of the vehicle.
Or you could just drive up to a wall, use the adjusting screws to lower the lights whilst car is empty, to regain the correct light height.
As above Xenons by law must do this automatically, if there is a system fault they automatically drop to the lowest levels.  If his are high I suspect the adjustment is out.
U sure it's xenon bulbs and not projector lights? Or hid bulbs ? Cause if you are talking xenon bulbs then all older cars using xenon bulbs are illegal. As to how bright xenon are that 30% brighter advertised is nothing I can hardly see the difference between old style halogen and new style xenon.
=_=
Regards
Steveuk260
I mean the system where the headlights have a high voltage warning symbol.
The correct name for this system I'm not sure as I have heard of HID and projectors?? Are they all the same or different??
This system is often referred to as xenon lights, as I understand. You are correct that this is not accurate as xenon is a gas which you can now buy for normal headlights.
