thatcherben Posted April 10, 2015 Posted April 10, 2015 Hello all, I've now had my 2.0 n/a Subaru estate auto for a few months and it's a joy to drive! Huge interior and a very cool/tough disposition on the road! What more could anyone want from a cheap motor.. Very happy! But... I have just purchased a set of 10mm wheel spacers on eBay, just to give it that slight edge with its stance, but the bolts aren't long enough to take the spacers and then the wheel nuts as well. Duh! Never thought of that, can anyone give me a heads up on where/what to get to remove and replace bolts or just not to bother with it? (Not a satisfactory outcome) Cheers
Gambit Posted April 10, 2015 Posted April 10, 2015 I have a set on the back but they came with the new wheel bolt extension on them. Bit like these
thatcherben Posted April 10, 2015 Author Posted April 10, 2015 Aaah right, mine literally are discs that are cut to be universal I think.. So either I send them back or try to replace the bolts. Not sure where to get them.
quit Posted April 10, 2015 Posted April 10, 2015 good one, you might need to get custom studs 5mm is normally the max you can get away with on standard
thatcherben Posted April 11, 2015 Author Posted April 11, 2015 Does anyone have s set of 10mm spacers (with their own lugs) for sale per chance?
Gambit Posted April 11, 2015 Posted April 11, 2015 I might be taking mine off but they're 25mm I had low profiles on but kept bubbling the inside tyre walls on the front with our crap roads. So upped the size tyres I was using but because I have mine lowered too the tyre on my drivers side over heavy bumps just keep nicking the rear arch now :( more annoying than anything I've checked the tyre it's not done any massive dame just see where it's taking a slither off the edge. :( so might have some for sale but larger than what you want :(
SparrowHawk.V8 Posted May 5, 2015 Posted May 5, 2015 On 4/11/2015 at 11:39 AM, Gambit said: I might be taking mine off but they're 25mm I had low profiles on but kept bubbling the inside tyre walls on the front with our crap roads. So upped the size tyres I was using but because I have mine lowered too the tyre on my drivers side over heavy bumps just keep nicking the rear arch now :( more annoying than anything I've checked the tyre it's not done any massive dame just see where it's taking a slither off the edge. :( so might have some for sale but larger than what you want :( Gambit, I might be interested in your spacers if you're getting rid. Would they fit an 05 Blob? My cars not lowered so I think they would be fine.
thatcherben Posted May 5, 2015 Author Posted May 5, 2015 Cheers gambit I would be interested, are they the centric ones? ha e sent you a pm. Cheers
ChrisD Posted May 7, 2015 Posted May 7, 2015 http://www.ebay.co.uk/itm/Wheel-SPACER-Spacers-FITS-toyota-Celica-94-05-NEW-2XPCS-25MM-THICK-5x100-T6061-/321738751437?pt=LH_DefaultDomain_3&hash=item4ae91fbdcd anyone know if these are useable? im thinking getting 4 and then on the back putting an additional 5mm spacer on each side
