Subaru needs help please
Hi I have a Subaru wrx my98, it is heavily modified, I am the first owner of this Subaru
I am having trouble diagnosing a problem with it if anyone has any info please help
The car drives fine and has no issues when cruising and foot to the floor, but when the car stops or stops at a traffic light that where everything changes, after stopping, when driving the car starts to jerk or pull or purge when accelerating to higher revs and will not go away, but when I turn off the car and the start it straight away and accelerate its like brand new until I stop and it starts jerking again
Hi welcome,
What mods does it have ,
Could be a maf sensor idle control valve or one of many other little things. Hole in an air little or a loose hose etc.
Have you tried the ecu code check ?
No but I have changed the air flow meter recently
I thought it was that but no it wasn't
How do u check the ecu check?
Have you done an ecu reset after the maf swap?
Are you running a aftermarket ecu or subaru one ?
I'm just on way home but there's a guide in the engines section i think
It's the standard Subaru ecu
And yes I have done an Ecu rest after the maf swap
It has a standard Ecu but a different chip
