Hybridize Turbo TD04L
Hello...
Can I have your opinion about hybridize a turbo TD04L, for an Impreza GT98...
By information of the garage that does that kind of service, they extract more 15 BHP...
This modification, and a new exausht with a prodrive pan, do you think is a good way to improve boost on the first gears???
TD05 its cheaper, and gives way more power than the hybrid, they run out off puff mid range and so are not cost effective.
Ok.
But tell me, with a TD05, I still need to remap??
you will indeed
Yes, although others have swapped and run with minimal issues without map
a td05 is a larger turbo so will give even less low end than an 04
stants, with the td05 I will lose more in low???
In the other topic you advise me to see the ECU or esl board in Www.enduringsolutions.co.uk. It is a litle dificult for me to find the right one for my impreza 98. Is it much to ask you,to find me the right one??
Whwn you need some favor in Portugal, i return the favor...
Thanks a lot...
