Td05 water pipes...
Thanks mate ive got my old man he used to be a mechanic but nearly 20 years ago so its all new to him.. and be both
  • Replies 56
  • Views 7.6k
  • Samuel_Kelham
    Samuel_Kelham
  • Samuel_Kelham
    Samuel_Kelham
    Silly questions rick .. can i push the elbows into the water pipes easily enough ..whilst the turbos in situe from the top? And pther than the 3 bolts on the turbo vracket ehat else needs to come off?
  • Rick 2014
    Rick 2014
    Yes you can mate I will get some pics for you in a bit.Im working on the car today
What does that mean mate? Wide band arf? I sas being abit idle im underneath now and i can see them alot easier so ill drop you a line if i get stuck again.. if i ever see you at a show ill buy you a big pint thankyou
No worries mate, glad to be of some help, wideband lambda sensors are for monitoring air fuel mix, normally used when mapping although people fit them to highly modded engines so they can keep an eye on things before they go bang [emoji50]
Well got turbo off in end managed to change all pipes clean everything up. .. struggled putting it bacl together (carefully)... tool best part of 5 hours.. thought wed managed it.. and now its tunning rubbish spluttering and ehat i can pnly describe as a sound like the turbines are catching inside the downpipe/exhaust housing.. im stumped put it back togetheras it came off didnt think wed damged anything.. so im realy stuck for ideas now... any suggestions ?
Sorry for the spelling i broke my phone keypad to :@ not a good day by all means..
I've no idea mate, try dropping savage bulldogs a pm he's taken then apart before, didn't realise you had to split the hot and cold sides to get at the pipes,
I didnt want to mate think i proberly went further than i did but it was just so awkward to get that bottom t peice connected back up.. ill try him.. gonna give it one last shot if i havnt broke anything and then ill throw towel in and take to a garage.. thanks anyway stants
