2001 wrx upgrade
Hi there, so I'm the owner of a 2001 wrx as of last week.
Wanted one for a while but family and work have got in the way.
So just a newbie question really where do I start with engine mods.
The car seems ok just a little judder/misfire/ hesitation at about 3500rpm.
Car is standard apart from a Bailey dump valve Samco hoses and a new walbro 255 fuel pump.
So I guess I'm just trying to eliminate the hesitation before upgrading anything.
Any ideas? I leave it with you.
Thanks for allowing me to join your group.
I hope to learn all I can about my new car.
Wotcha and welcome - feel free to get stuck in share photos etc, all friendly on here. Are there any codes generated / logged?
Welcome.
I expect its the dump valve casuing it. can you take it off and see if its improived without it?
Has the car been mapped at all?
No other mods. I'm unable to read codes until my
cable comes tomorrow. Can't take d/valve off as I don't have to old valve.
Thanks guys will no more tomorrow when I can connect car to laptop.
Just one more question guys. What coolent do I use in my car. Going to flush the system this week.
Make sure it's silicate, phosphate &aminate free, 90% of coolants are these days but etheleyne glycol stuff contains silicates which eat the water pump impellor , vest bet is getting a longlife O.A.T coolant, most motor factors sell it and Just do a 50/50 mix.
When was it last serviced ?
Last month but no mention of coolent change on bill.
Right guys got my laptop cable today. Checked for faults no recent faults found but did have a cam shaft sensor message saved. Is this an issue and what do I need to check. Thanks again for helping me out.
The coolent wouldn't make it run rough.
If it's been serviced then I would check the HT leads and listen if there is any loud ticking from the injectors ?
If the crank sensor fault is not there now it should be ok ?
yep, that's the one, very good price too
welcome to the club
where abouts in Barnsley are you?
there are loads of us from Rotherham/Doncaster/Barnsley area, we usually have monthly meets too. you are more than welcome to join us
Hi pal I'm in Carlton. Sounds great let me know when next meet is.
That's not too far from me, I'm in Mexborough.
I met up with ChrisD this morning and went out for a drive, then I went to see aucky in wombwell to pick some bits up this afternoon too
Might be a MAF problem, could be worth just giving it a clean. It's amazing what problems a dirty MAF can bring.
Is there a walk through on how to clean my maf on this site.
Cheers.
Don't think so, I watched my brother in law do it (he's a mechanic) and he took the MAF off and sprayed electrical cleaner inside. Then waited for it to dry out before plugging it back in, worked a treat for me.
Just one more thing for today lol.
Is my diff oil and gear oil the same I can only find 2 dipsticks
Subaru manual says there separate but I can't fine any more dipsticks.
This is the front sorry.
I know how to check my rear diff oil.
Yes mate the dipstick for the gearbox is also for the front diff, it's a combined unit, it also acts as the fill up hole for the box oil !
Rear diff you'll have to undo the top nut on the backside of the diff as you look at it from the rear, should be just about level with the hole if the levels correct
Where is the meet pal.
Barts, it's only 5 mins from the M1 J34. always a good turn out and worth the run out
