Tyre Speed Ratings - different rating used on front and back axles
So I'm about to order a pair of new tyres ahead of my MOT next month. The one's I have my eye are are a higher speed rating compared to what I'm running currently (W rather than V). They will be fitted as a pair on the rear axle, so will be running V's on the front, W's on the rear until the fronts need replacing later this year.
I've read up on this as much as I can and from what I can gather it won't cause any problems, either day to day or MOT wise. Does anybody 'in the the know' know anything different please?
David
No is the short answer.
The longer answer is: Mixing brands and specs is rarely advised. It may create resonance simply through different types of rubber, however this is aesthetic, rather than safety oriented. As far as safety is concerned, the speed rating is an upper limit the tyres are rated to and, unless one of them is below the national speed limit/the speed you're planning to drive at, you'll notice no difference.
Cheers Oj 89 - I will be matching them all up later this year; just don't want to waste the rubber left on the fronts (4-5mm)
I had different ratings front and rear no problem. Crappy ditch finders now in bin
I'm well impressed by the good years, sooo much grip in the wet & braking is awesome too
Ah well you with your fancy big rims ! One of the reasons I chose to stick with the oem size
haha nothing wrong with a bit of manly rubber - just ask gambit  :P
I'm still on OEM too, but I'm sure you know that mate  :)
I know I'm just waiting for his appearence at japshow, rumor has it he has one of those blow up suits as his party piece this year
suuuuuummmmmooooooooo!  :D
I was told more like this
I thought they'd be good...I've run goodyears on previous cars and was always impressed with grip and longevity too
Thought I'm never gonna run out of grip in the dry so may as well get a decent combination of grip/eco. Just need a geo set up, delayed as I've got some more suspension bits to put on but they haven't turned up yet
I'll treat myself to a set of goodies when I get my Foz import in a few years time [emoji6]
