major hesitation on low revs
hello all need some help if anyone can
i got a my98 wrx jdm
had recent rebuild engine works perfect the problem got is when intial pull off from 1k revs to 2k revs jumps and kangeroos like a really bad misfire, after 2k-2.5k revs it feels good under boost, fromcold it runs low idle and lumpy,when hot tends to settle down,hoping someone got some ideas
work done
new irridium plugs and leads
newfilters all round
checked allboost pipes are in correct postion (3 port solinoid)
no vacum leaks or boost leaks
checked all intercooler/turbo pipes
disconnected maf engine cuts outs
dsconnected lambda sensor has no change still does same
wondering if anyone nows what to check next thanks
Coil pack?
sorry forgot to say coil pack is new,
everything is totally standard, basically bought the car last month with no.3 knocking, so new rebuilt engine everything has been plumbed in correctly no leaks or plus loose,been double checking everything ova and ova.
on the 3 port solinoid ive left the bottom hose to vent and blanked off the pre turbopipe it slightly improved but still there on verylow revs
i was checking all the pipes to make sure everything was in the right place a nd no leaks were present, are you recommending to get it mapped and you think that will steady everything. thanks
yehi think your spot on there as thats the point im at tbh thanks
Have you done a classic self ecu code check ?
Maybe Check the plugs to the tps and icv maybe give the icv a clean as well
I don't think a v4 jdm wrx is supposed to have a 3 port boost solinoid and I just did a quick Google and come up with this
MY98 WRX (JDM) ... 2 port solenoid 0.9mm restrictor fitted between the turbo and the tee piece
I only mentioned the solinoid as to change from 2 port to 3 port requires a map tweek.
Symptoms do sound like a possible air leak from the inlet but start with the ecu Check as it could be something totally different
Thanks for that, that's what was all fitted with the car seems a weird one as I no the 3 port is Spose to b better, I'll have a try on the Ecu check see wot it comes up with and go from there
Just to let people no who offered advise, I done a smoke test and found a leak from the throttle body I ring so new one needed thanks for all help
Just waiting for the throttle body then all should be sorted
Well throttle body has been replaced, so no leaks so that's that sorted but still same no difference, still hesitates, lumpy when cold start, when hot idle levels out and not so lumpy, sometimes when pull up to junction revs hold to about 1200rpm for 5-8 seconds then slowly drops back to normal, when turn car off then go to restart it idles lumpy and really low revs like ready to cut out then picks back up after about 3-5 seconds, checked everything possible, boost on idle sits at 0.6 then when fully boost goes just above the 1.0 on my gauge. Any body got any thoughts where to go next
Have you done a classic self code check? If not there's a how 2 in the tech section on here
Have you tried cleaning the idle control valve and checked that the little gauze filter isn't perished?
If it's not been remapped it should only boost to 0.7 bar ish ,so it's over boosting a bit .
Yeh I've done that comes up with no faults just constant flashing, I've reset ecu, cleaned the icv the orange gauze is like new all cleaned as well, there's no remap or mods everything is standard, I got a hks gauge u saying that when I checked sometimes it went just below the 1 then in ova gears it went rite up to the 1.0 bar and slightly ova, if it's ova boosting any ideas wot the likely cause could be thanks
Forgot to say there's no leaks as the smoke test 2nd time came up perfect
It is but still have same prob pmsl this one got me scratching me head
Over boosting is usually caused by someone fitting mods that let the turbo spool more freely (Decat downpipe, cone filter ect...) but it can also be caused by vacuum ,boost solinoid, actuator or map issues .
Sounds like your best bet is (as tidgy said) to check your timing marks and get it on a dyno .
As a decent dyno operator might be able to diagnose the issue and save you spending a small fortune on random parts trying to stumble across the fault .
You don't want to be giving it full boost until you know your afr is correct cos if it runs lean it will go bang again [emoji53]
  • 5 years later...
I am driving a Subaru Impreza 5Door 1.5R 2009. Recently when I drive on the high way at 2,000RPM and try to over take others vehicles, So I accelerate, The RPM will jump up to 5,500rpm. But Now it will cut off at 4,000 rpm or 3,000rpm.
If at 5,500rpm that's mean my fuel consumption will be at 11.5km per liter, But if it's at 3,000rpm that my fuel consumption will drop to 6km per liter.
Can anyone experience it? why? ? is the injection issues?
Once drop till 3,000-4,000rpm it is very difficult to go back to 5,000rpm until now my car still at 4,000rpm or below.
It can be ram up to 4,000rpm but it take more time like another 3-6 sec .
any one know what happen?
Edited by Robin Koh
Give more details
