clutch type for 97
hi
I have a 97 impresa turbo but need a new clutch soon, as its right at the top for biting,,
ive been looking for clutches on different web sites and there seems to be so many version of them
my model number is gc8ek8d
my engine number is ej20gnw6nd
any help would be great
cheers
Used to have a stage 1 organic in my one
What power will be going through it ?
Can't go wrong with either the exedy blue box good for 300bhp ish or pink Box for any more than that
hi thanks was looking into an exedy one .. are they all 225 mm clutch plates or do they vairy over years ?
Should all be the same throughout the model
magic cheers for info :)  hopefully an easy job as doing it myself lol
The engine layout makes the bell housing easier to get to just don't forget to unplug the neutral pristine switch ad the wire I'd short
ok cheers gonna do a bit of research into it on you tube ect b4 I give it a go :)
ok kust been on the phone to euro car parts and gave them my vin number, turns out the clutch is 230mm and not the 225mm one  so just ordered an exedy one for £230, and just been quoted 390 for fitting for local garage
Not bad price might take off my 6 paddle soon
Give "Asperformance " or "lateral performance " a bell as I think they sell the uprated pink box clutch kits for about £280 [emoji6]
Main thing different about fitting a scooby clutch is they're "pull clutches" so you have to remove the clutch fork pivot pin to release the thrust race before you can split the engine and box.
I'd also recommend getting the flywheel skimmed as if the current clutch has worn the flywheel you'll probably end up with "judder" due to the uneven surface not making full contact with the straight new clutch plate face
clutch now fitted ! exedy clutch 230mm from eurocar parts £231 fitted at at autos Grimsby for £390 including vat
Give Dan a ring mate down railway Street or I can see what he will charge ya if you like with fitting. But I drove through to Sheffield to let Martin do mine at Sheffield Subaru services. Had a cheeky nandos too lol. Think he charged me 280 supplied and fitted.
With a skimmed flywheel.
