Grinding noise on cold start (07 WRX)
Hey guys,
I'm finally the proud owner of an 07 Impreza WRX and absolutely love it! I've noticed however that whenever I do a cold start, there is a grinding noise coming from the passenger side of the engine bay that lasts for 10-30 seconds and then stops, only to return when the engine has fully cooled down.
Increasing the revs and pressing down the clutch doesn't seem to make a difference.
Everything seems fine when the noise has stopped and haven't had any other problems.
I think the source of the noise is coming from the part that I've circled in the image but I'm not 100% sure. I'm not too sure what this part is, any help would be much appreciated!
I've read somewhere before that It's a heater fan that blows onto the cat to lower emissions from cold.
Yeah that makes sense, it would explain why it makes the noise when it does too. luckily I have warranty with the dealership so they should hopefully be able to sort it out. Cheers.
No worries, hope they sort it for you :)
it's the so called secondary air system active with a cold start. if you have a reprogrammable ECU best to cancel it out and close off the two secondary valves too as they will get broken too as they all do... good old Google is you man to find loads of info about this wonderful system  :ph34r:
Thanks for the info! Yeah after a quick google it seems that the valves getting stuck is a fairly common issue.
Hopefully it won't be too much of an issue to get this sorted.
