Burning oil/rubber smell when going high speeds only
Recently got a 2011 WRX STI type UK it's my first Subaru and first turbo and AWD car so I thought I'd take it for drive to see what it can do, it's 100% stock. I made sure the engines nice and hot before I floored it and when I started getting near the top end I could smell an oily/rubbery smell it seemed to come through the vents so when I got back I looked it over and couldn't see any oil leaks or anything, any one have any ideas? Would be much appreciated.
Possibly cam cover gaskets weeping ? Usually the o/s one as it's close to the downpipe and gets hot and perishes, have a look between the airbox and side of engine, directly down you'll see some oily residue on the up pipe if it is weeping
I'll have a check tonight, is it a common thing like?
Sent from my iPhone
Yep, due to the layout of the engine the oil pools on the side of the cam cover when cool and makes the rubber slowly go brittle with heat.
Ahhh ok thanks bud I'll check it over after work
Sent from my iPhone
If it is what you said, is it a serious problem? Or just wear and tear etc....
Sent from my iPhone
Wear and tear they all go at some point
Ok cool thanks
Sent from my iPhone
It's a pig of a job so if your handy with the spanners it's under fifty quid for both sets of gaskets and half moons. But expect lots of swearing and pain, if you can't be arsed then it's roughly an hours labour.
Haha nice haven't broke the spanners out for a while so I'll decide when I see it lol
Sent from my iPhone
May not even be the rockers but it's fairly common. Best investagate beofre hand lol
Will do mate, thanks for heads up
Sent from my iPhone
