Has anyone upgraded their sat Nav at all as I've noticed it's really dated as was setup in 2005. Just after ideas really as replacing the screen for something modern would be good. Cheers
Sent from my D6603 using Tapatalk
have a look on this forum as it has been done. btw the box with the satnav on your dash is double din...
Ok cheers bitman, I did have a search earlier but couldn't see much.
Hi, I got !Removed! off with mine too - maps out of date, very slow, kept defaulting to Belgium for some reason.
I removed the original display and the DVD drive/box in the glovebox and fitted a Garmin Nuvi 65.
It fits nicely with a bit of fetling, used the windscreen suction cup stuck to a bracket I made from a bent piece of aluminium araldited to the top of the original satnav pod. Fitted a cigar lighter in-line plug to the original display's cable and used the original Garmin car charger.
It switches on and off with the ignition and works MUCH better than the original. Got a load of space back in my glovebox too :-)
HTH
Steve
Hi Steve, funny enough I was looking at sat Navs in halfords to see if that was a possibility. My ideal is a nexus 7 install but not totally sure how difficult that's going to be. Thanks for sharing anyway!
Cheers Lee.
Cheers Lee.
Should be fairly easy there's a couple people done it already, Gambit has a full pc wired up i'm his !
the hardest part is getting it to look 'propper' in my opinion
Hi stants, yes that's the other issue trying to make it look like it's came from the factory with it installed. I'm having a mare trying to sort a Bluetooth obd2 reader too the elm327 one I got won't work and I'm having difficulty finding a compatible one as this will be running through the nexus 7 ideally!
Subaru won't do eml327 need one with a different protocol have a look for the torque app and one on either ebay or a more detailed one
There's a thread I'll dig out for you
That explains it then cheers, will have a look on the torque app website.
  • 4 weeks later...
Hi, I spoke to David at satnavdvd.co.uk and got a Core 1 disc for the Forester SG. It arrived in 48 hours and works really well. Doesn't change the rather crummy UI but updates the maps. Great for £34.99 !
post-5197-0-20787100-1444738002_thumb.pn
Cheers for the info I will check that out.
