Help with overheating
Mikeparkyn11
Hi again all. Since my last post. I have had a friend look over it (mechanic) he's done a sniff test. Very puzzled. Sniff test after a few minutes went yellowish green. Meaning head gasket then, he said will do a 2nd time just to check and then it didn't change colour? It over heats after about 10mile drive every time or after about 20minute drive. Its still got this problem. He did take rad cap off and start her up and said that the coolant shouldn't be spitting and bubbling out like that... also.... top rad hose hot and tight? Bottom cold thanks guys
Ok so had sniff test done again. Been told it's heads. Been told I have managed to drive to work and back because the head is fine but when exhaust gets hot it makes head expand taking the exhaust gas and pushing into coolant that's why there no oil in water and water in oil. I am now wondering on what kind of price I should be looking at or if anyone can recommend someone near Aylesbury Buckinghamshire
