Hi , any help would be greatly appreciated
Hi Iv have a s reg turbo 2000 wagon , it's got yellow injectors (been told they are standard) ?? Not sure if they are or not , also Its got a 3pin e3 Ecu on it , wondering if this is mappable or if I need to get a different one ? Thanks for any help
Everything is remap able in some form or another mate !
You need a esl board on that to map it ( enduring solutions )
Or you rip it out and go for like a apexi unit
Wicked , could I put a wrx 3pin Ecu on it with a td05 or would that not work ? Thanks
The only thing it would achieve is bad detonation and destroying your engine
Plus you won't gain anything at all really
s reg will be a version 4, which the standard ecu isnt mapabel. the choices you have are to put a daughterboard in ESL etc or aftermarket ecu (funny we were just talking about this on another thread lol) personally in your shoes i would go aftermarket via alcatek. Other option is syvecs but that will be alot of money
Wotcha and welcome - feel free to post pics and get stuck in - savage has a great classic build thread you may find some inspiration from :)
Thanks , to be honest I think it's a v5 mate , from getting rocker cover gaskets and also the coil pack is to the right hand side , and I will have a look see if I can find him
