belts seems to be squeaky now the cold weather is kicking in...
normal or needs checking over?
Yeah literally start up reverse out of space then drive to end of road and it goes
Meh, I spray mine with belt slip now and again but would only give it some attention if it continues past the end of the road and beyond.  You could always give it a slight nip up.
Anyone else had any issues if not addressed on a boxer at this stage?
slight re-tensioning should do the trick, easy to do diy .
How easy
