Car is dead after jump start
OK started my car earlier and reversed on some ramps while exhaust was welded and battery removed.
That was completed and put battery on and had to jump start car. However car just turns and turns. There is fuel getting to the engine while I was cranking there is spark. But car does nothing but crank. Any ideas please guys.
  • Replies 75
  • Views 7.6k
    Check cam and crank sensors haven't been unplugged by accident while disconnecting the battery. Check the fusible link ,it's a bit of wire with a spade connection on either end in the under bonnet
  • As savage says 👍 this should also help! And for cam Sent from my HTC One_M8 using Tapatalk
    Did you disconnect the battery earth or just the positive side? It seems strange that it's happened after welding How do you know it's got fuel and have you done a ecu reset? Might be worth C
Battery Is not much good. Needs a new one but same problem with a good battery
Check the fusible link ,it's a bit of wire with a spade connection on either end in the under bonnet fuse box .Although if this has blown it doesn't normally "crank"
c04d8f91d39999bd32ec7e8515988740.jpg3c100c993d7233ab3920af02c4bc7d80.jpg77e6897c4940f38760f978a3daceaf45.jpg
And for cam
Would any of those have a blue connector
Thanks mate. That's my Saturday sorted.
Checked eml and all clear on that
Lev if u want ill take more pics of the book but ur ecu is prob different so ull have to find the wires and terminals (shouldn't be too hard) keep me filled in!
Might be worth Checking that the big grey plugs at the ends of the engine loom and that the gearbox /inlet manifold earth's are ok .
Make sure the contacts r clean on the battery cable! And the batte
The last thing I did was kick the wheel, hurt my foot and sat in the living room sulking.
Could jumping the car have damaged something? I have heard of using jumper cables blowing ecu?
Calm down mate we got you covered! I have a book, you grab a multimeter and we get cracking on this
Tell me what model ecu you are running and if it's UK or jdm
Will get all info in morning. Jeez you guys on this forum are !Removed! great. Best thing I ever did was sign up here. I really hope it's something stupid lol.
If you get me the ecu model no I can do some research and be a little prepped for tomorrow 😂😂😂😂😁😁😁
My neighbours think I'm nuts pulling car apart 11 at night lol
I've done headers at midnight in the rain YOLO 😂😂😁
Haha. I just can't seem to leave mine alone lol. I can't wait till all these little niggles are sorted.
And lastly what type of ej20 does it have ?
You can check on the metal tag under the bonnet
Do it tomorrow though!
It has a closed deck block with a UK 2000 top.
Not the original engine
Have you had any luck lev? Did u check the sensors like savs said ? Sorry bout the late reply; shipload of drama today 😂
