Strange noise when turning right
Hello, I own the subaru outback 2008 2l diesel boxer, yesterday I noticed that when I turn right there is a strange noise. I don't know where does it come from or why but I suppose its from the hydraulic pump or there is not enough oil in there. Have you got any suggestions?
Can you describe the sound?
Check your belt see how loose that is. I'd try figure which side it is and check pads for the amount of meat on them inside and out. And why you have it jacked up give the wheel if it has play in it might be the bearing going.
Can't really describe the sound, but its not cracking sound or something like that, its like a fast car going by you.
And could you as well tell me where can i find the hydraulics liquid tank?
Sorry for the double post.
Sorry, not sure if there is a reservoir for the steering pump. Does it make the noise at any degree of turn or at full lock? I know my wifes car when it is on full lock the belt squeaks a bit...
Could also be your stone guards on the inside of the brake disc that's collected some dirt and is just rubbing away
It's not the belt for sure. It does it randomly not always.
Will try it.
Wheel bearing ?      Pad wear indicator - Manual spring type?
Mart
