Help Required If Possible
Hi all,
I have a uk2000 W reg, i have only had her on the road for 3 days and have notice a few problems if anyone is able to help me with
1) When at 2,500rpm it feels like its holding back but if i keep accelerating it kinda kicks in and off it goes
2) When accelerating I get a continuous hiss coming from drivers side of the engine until i let off the throttle and then it continues again.
Thank  You
Sounds like an air leak. Check all boost pipes are connected and not split. Check any jubilee clips on intake pipes. Have a good look around and stick your ear under the bonnet, give her a rev then try to pinpoint the hiss.
Sounds like possibly a air intake or boost leak . As either 1 of those would give a "hissing" sound and lack of power .
Try checking for any loose pipe clips or cracks in the pipework from the maf (just after the air filter) to turbo intake .
Then from turbo outlet (under the top mount intercooler ) to throttle body.
Also check any of the small bore vacuum pipes for cracks as these can also leak boost and are prone to perishing .
thank you for the replies, i was wondering also why would i have oil underneath the tmic and also a bit on the top of the gearbx?
