Diabolical running issues
Hi all,
I have a Uk2000 Turbo, i have not long owned this vehicle but thought i had a decent runner until things started going down hill.
I had to replace the turbo with another td04 because of a lot of play, I have cleaned the throttle position sensor and the one above it (plunger type) as well as replaced the knock sensor - all was running ok.
I took it for a spin and noticed its still hesitating from 2000rpm up to 3000rpm - after that its fine, i returned to mates garage and left the car for a few hours and then drive home, its got worse, the car is running lumpy to the point of cutting out the idle is all over the place and there is a nasty burny smell coming from the exhaust - I am stumped as well as my mate too, if anyone could shed some light on this it would be much appreciated.
Leftover oil in the exhaust for the smell? As for the running issues it could be made sensor?
i've had a replacement inlet pipe put on last week, i originally thought it was fuel starvation or along the lines of spark plugs failing between 2k-3krpm until an awful 5 minute drive home without boost started
Was an ecu re set done after changing the sensors ?
The tps and knock sensor have to go back in at exactly the same position as they come out, otherwise it will run crap,
update
after using the cars built in obd here are the codes as follows:
22 Knock Sensor
23 Mass air flow sensor
31 Throttle position sensor
45 Map sensor
24 Idle air control sensor (usually companied by running too fast/Slow)
32 O2 Sensor
i can only assume the knock sensor is coming up as its detected poor running,
What fuel you running it on out of interest?
i am using shell v-power
whats the best way to clear them? does removing the battery terminal reset them?
i removed the negative wire, I took the car out for a drive and it all started playing up again, kangarooing between 2k-3k, there is no pipes split, the boost solenoid has been cleaned out, the idle sensor above the throttle position sensor was also cleaned out with carb cleaner
