computer management software for 1997 8s ecu and another Q
hey peeps hope your doing well, quick question, if possible, is there any computer management software for live monitoring of a 1997 uk turbo 2000 with a 8s ecu.
So far ive tried the elm327 and the "freessm" via usb to odb2 cable.
I really want to have a look at the live stats for my car to see the fuel trims etc and especially knock (if any) as i have a subaru which literally has all sorts of funky things installed such as a stage 2 clutch, ra gearbox, decat, a supposedly stock td04 turbo which has been debadged (??why idk lol) i really want to know if everything is fuelling and boosting properly
Just wanna see how good if possible the ecu is adapting to all the funk.
I pulled out some manual boost controller hoses and most importantly a funky superchip (which i need to break with a sledgehammer still :D)
I also really want to map my own car so im learning all about ic engines at the moment and i hope to get a esl board strapped onto the 8s and get some road tuning in (whilst doing massive amounts of research).
Any pointers/encouragement/discouragement will be really appreciated.
Thanks for reading !
Www.evoscan.com is your best bet for (cheap) monitoring.
I'll run mine on the way to work grab some shots for you, can't map or anything but it's useful to see if all present and correct.
You'd need to buy an esl board direct from.them with cable if you want to be able to map &log properly
anyway i could try it before buying it just to confirm it works?
Well the thing is the evo scan software needs a cable which unless you are any good at making them up you'll need to order from them, no problem I hear you say, trouble is they are based in NZ and it takes about 4 weeks to arrive,
You do get a discount if you but the cable and software together.
If you were closer you could borrow mine but it's a bit of a drive I think.
Oh and I was late for work so legged it out the house and forgot laptop so I'll have a go tomorrow for you
isnt it just a bog standard odb2 to usb cable (i have one and it fits in just fine) ?
Nope as the older versions run ssm1 and the odb port only has 6 or 8 pins I think
thanks for the pointer, ive now found a document explaining how to make the cable and i will proceed to make the cable, thanks!
Boom !
Happy days
Any chance you could share the link / document?
I'll get it to you now, although there is a pretty hard to find part (I assume) and it also might just be more economic to buy it but let's see (although making it is super cool haha)
Sent from my HTC One_M8 using Tapatalk
Right excuse the crappy pics as I couldn't print screen for some reason,
On 15/06/2016 at 7:16 PM, stants said:
seems almost perfect, does it have a way to show boost psi?
http://www.alcyone.org.uk/ssm/usbhowto.pdf
sorry about the late reply!
There will be as you can have lots of different skins/interfaces to show what ever you want, I don't really use it that much at the moment
