Water temp sensor location
As above where abouts is the temp sensor on a uk 2000 t reg thanks
It's in the water cross over pipe underneath the intake manifold, if you remove the alternator you should be able to see it,
There's two one for the ecu and one for the dash display
Ok I might leave it for a bit coz it was only for another water gauge so I can keep a proper eye on it
That is another way then I will have a look for the adapted then
