Temp sensor
Don't think the ecu would back the boost off if it's sensing exessive heat but a engine that's too hot might tighten up the tolerances enough to cause drag/wear to affect performance.
If intake temps are high or its over fuelling you'd loose a bit power .
Is it boiling over or just seems to be running a bit hot ?
well is wot i have done and found out
i had a intermittent power problem that seemed to be linked to how hard you pushed it as it, if you put your foot down for a good 10 min you would start to get a power loss then if you backed of for a few miles and let her cool down she would go back to normal.
now iv just changed the temp sensor and it seems to be better but i have only driven home from work
If it's a recent thing (since its been hot) it might be tmic heat soak , have you got the turbo /downpipe heat shields in place?
if not is your downpipe "wrapped" to keep the heat down in the bay ?
wot is  tmic heat soak
and there is no downpipe heat shields in place and it is a 3" down pipe not warped
but i have got some wrap in the workshop
The early top mount intercoolers are the least efficient in the range and rarely make over 300hp when mapped .
So keeping engine bay temps down helps keep the tmic from soaking the heat into the intake air . Giving colder denser air and more hp [emoji6]
Don't wrap the whole downpipe ,as it will get wet under the car , just the top and vertical bit .
ok will do that tomorrow see wot happens thanks once again
Turbo blanket may help too
