RedRocket Posted August 2, 2016 Posted August 2, 2016 Just rebuilt my impreza gc8 2 litre turbo ej20, just want some advice on the best oil grade to use? 2
stants Posted August 2, 2016 Posted August 2, 2016 For the purpose of running in or generally ? What's the build specs as may dictate slightly different oil ,I'll let @savagebulldogs point you in the best direction Sent from my SM-G930F using Tapatalk 1
RedRocket Posted August 2, 2016 Author Posted August 2, 2016 In general, has td05 an air filter not much more really i do have some 10w 60 from my m3 but not to sure about that? And i have 5w 30 petronas fully?Â
stants Posted August 2, 2016 Posted August 2, 2016 10-40 fully synthetic is what's recommended for classics Sent from my SM-G930F using Tapatalk 1
Phillip1993 Posted August 2, 2016 Posted August 2, 2016 I was aways told to use as cheap as possible for the first 500 miles preferably a mineral oil as modern oils are to slippery and don't alow the rings to cut the top off the peaks that the honeing leaves behind 2
savage bulldogs Posted August 2, 2016 Posted August 2, 2016 Generally most people run in for 1k using mineral oil gradually increasing the max revs from 2.5k rpm in stages of 1k rpm per 100 mls . Refresh the mineral oil and filter at 500 mls ,then start using spurts of low actuated boost (0.5 bar max ) low down in the Rev range for the next 500 mls . This helps to bed the rings and lessen the chance of glazing the bores . If it's been rebuilt with standard internals using standard tolerances most use millers 10 w 40 fully synthetic after the running in period on a classic. If it's not broke .....upgrade it 😊 1
RedRocket Posted August 3, 2016 Author Posted August 3, 2016 I currently have 5w 30 semi just whilst i started the car, but have ran it for a good hour on idle, and done about a mile so far just wondering if i need to chamge it before i do the 500 mile bed in?
savage bulldogs Posted August 3, 2016 Posted August 3, 2016 Not too sure to be honest as I've only ever been evolved in the running in of 2 turbo engines and we used the method above for both my forged scooby and a mates skyline. You could maybe drop the semi out (ooh er misses ) @ 250 mls then change to 10 40 mineral with a new filter before you start using low boost ? I ended up using 2x millers running in oil and now run millers 10 w 50 nano drive with a Mahle oil filter . Phone tim @ Opie Oils as we get a club discount and he knows his oil options [emoji6] Keep us updated on how it goes and all the best bud [emoji106] If it's not broke .....upgrade it 😊 1
Tidgy Posted August 3, 2016 Posted August 3, 2016 running in, 500 miles with !Removed! nasty mineral oil, 500 on semi synthetic, then change for full synthetic and map away at 1000 miles. 1
RedRocket Posted August 3, 2016 Author Posted August 3, 2016 Thank you very much lads much appreciated, will keep you informed so we all know when it goes pop again😜😜
RedRocket Posted August 6, 2016 Author Posted August 6, 2016 Could only get hold of 15w 40 mineral oil so im gona run that for 500 mile put a filter on with it, an after that change filter an put a good 10w 40 fully ?
savage bulldogs Posted August 6, 2016 Posted August 6, 2016 Should be ok , just follow the gradual off boost rev limit increases and then use actuated boost low down in the Rev range. If you cant manually turn the boost down (via apexi ecu or a controller) You get actuated boost by buy passing the boost control system . run a vac line from turbo outlet to actuator and plug any vac lines /ports you disconnected. This should give you a max 0.5 bar boost limit so you don't have full boost untill the engines run in with proppa oil [emoji6] If it's not broke .....upgrade it 😊
RedRocket Posted August 6, 2016 Author Posted August 6, 2016 Like that you mean? Because im mapped to run 1.5 bar😜 1
Tidgy Posted August 6, 2016 Posted August 6, 2016 Disconnect the actuator and keep it under 3000rpm :)
savage bulldogs Posted August 6, 2016 Posted August 6, 2016 Imo you need to rev the engine to more than 3k off boost and then (once you've run it in off boost at higher revs) use 0.5 under 4.5k to bed the rings in to stop glazing of the bores . But as I said before, I've only ever used this method for 2 turbocharged engines , so it's just a opinion [emoji6] If it's not broke .....upgrade it 😊
Tidgy Posted August 6, 2016 Posted August 6, 2016 57 minutes ago, savage bulldogs said: Imo you need to rev the engine to more than 3k off boost and then (once you've run it in off boost at higher revs) use 0.5 under 4.5k to bed the rings in to stop glazing of the bores . But as I said before, I've only ever used this method for 2 turbocharged engines , so it's just a opinion If it's not broke .....upgrade it 😊 neither of my engines have been and they have both been crackers. As you say opinions seem to vary on whats right and wrong, my advice is go with what your builder says.
savage bulldogs Posted August 6, 2016 Posted August 6, 2016 I think he rebuilt it himself [emoji6] I've got nowhere near the experience as s.c but personally I wouldn't think that the first time a freshly built engine hits over 3k should be on full boost while being mapped for the first time . If it's not broke .....upgrade it 😊
RedRocket Posted August 6, 2016 Author Posted August 6, 2016 Yeah i built it myself i was just going to drive it at low revs about 0.5 boost ? Guessing you guys reccomened unpluging boost controller?Â
savage bulldogs Posted August 6, 2016 Posted August 6, 2016 What boost controller is it ? And no just turn it down to 0.5 bar , bud If it's not broke .....upgrade it 😊
