Help with Denso ECU
Hello,
I'm looking for the pinouts of the Denso 22611AE880 F2 ECU. Can someone please help? The car is a 1999 forester, the VIN is JF1SF5KJ4XG019013. Thank you very much, regards,
Ico
Sorry wouldn't know where to start. :sad:
I have a avcr booklet which has a few pinouts listed but only the ones needed to fit it .
What are you trying to find the pinouts for ?
As i might have them but If it's the full list "google" is probably the best option .
Thank you for your answers. Savage, even few pins will help, thanks!
I need the pinouts because I'm converting a VW T25 to Subaru engine. Since I need to rewire everything, a pinouts is essential.  I already googled every possible combination but with no luck. I found a lot of pinouts and schemes but for the bigger ECU, not this Denso the Forester came with. Anyway if someone has any information or is better googling than me please let me know. Thank you!
Ico
Sounds like a great project. I did google before I replied and same outcome :baby:
Have a look in the subaru forester service manual, that ecu not not uncommon & shared with impreza too .
Clear image of the ecu & the connector port may help supply a matching pinout diagram .
Cheers Mr B :biggrin:
  • 6 years later...
Hello I have the same problem, does anyone have the pin out of ecu 22611ae880
