Hazel Posted September 14, 2016 Posted September 14, 2016 Hi, the DPF light has just come on on my 7yr old outback.Shortly afterwards the malfunction indicator lamp,vehicle control dynamics control & brake system lights all came on at once. It has done 78,800 miles & has had two new sets of glow plugs in 12 months,(second set replaced foc). The problem i have is my local garage doesnt have the full diagnostic package, the "Subaru" garage in Hexham, 18 miles away, is not actually a subaru garage & i have had issues with them (see glow plugs!!). SO, i need to travel to Newcastle, 40 miles away just to get diagnostics done at £80 a shot. SO, before i venture that far, can anyone shed some light as to what might be going on & is my car safe to drive in the meantime please? Thank you in advance Hazel
Gambit Posted September 14, 2016 Posted September 14, 2016 I know sounds silly but just check that the petrol cap is secured tight enough and has nothing blocking it from sealing properly. This will bring a light on as the ecu thinks it has a leak. I would see first if the car drives ok before trying to drive it far and to see if the codes clear once you have checked the cap. If it doesn't then certainly will need to be looked at further.
Mark D Posted September 14, 2016 Posted September 14, 2016 Don't know about Subaru, but I think some cars have (or had?) a tank to fill in an additive for the dpf which was done at service Sent from my iphone using Tapatalk
W444AJD Posted September 14, 2016 Posted September 14, 2016 my last car was an Audi A3 with 1.9 TDi engine and a DPF - it had done about 78k miles and the DPF was beginning to get pretty sooted up. Often the dpf warning light would come on. I used dpf cleaner and regen fluid in the fuel tank (something like Fotre) - then you could drive it, even in limp mode, to try and clear out the DPF a bit. This was a VAG engine so I don't know if Subaru diesels will like being driven in limp mode? But I would try some of that fluid before going back to garage again.
Hazel Posted September 14, 2016 Author Posted September 14, 2016 Thank you for your help. I tried tighteneing the fuel cap,it made no difference, unfortunately. I will try a DPF cleaner, see if that helps. I appreciate your input
stants Posted September 14, 2016 Posted September 14, 2016 You can do a forced clean out and dpf re gen, not sure about the exact procedure but@dogconker is your best bet Sent from my SM-G930F using Tapatalk
Hazel Posted September 15, 2016 Author Posted September 15, 2016 Thanks Stants.I have asked @Dogconker their advice.Garage are quoting £1700-2000 for a new one & i dont think the car is worth that.
awebb320 Posted September 16, 2016 Posted September 16, 2016 you can remove the dpf and send it away to be chemically cleaned. i would also check to make sure all ecu updates are done and a forced regen procedure when put back together. the other daft one is the intercooler hose, if that devlops a small split then it will keep trying to ad extra fuel and eventually the dpf regen cycle will stop and the lights will come on alex
Register a new accountSign in
