JamesJDMwagon Posted September 26, 2016 Posted September 26, 2016 So I was having a great day then the old girl decides with no warning not to start to cap it off I had to be toed home by a Civic!! The embarrassment 😖 . MBut on a serious note my fuel pumps only getting 1volt I'm scratching my head, any ideas?
Rps Posted September 26, 2016 Posted September 26, 2016 If i had to get towed by a vtec kicked in yo id set my car on fire lol Feel for u mate its crap when they dont work right init Ps i know this post is 0 use to u lol 1
JamesJDMwagon Posted September 26, 2016 Author Posted September 26, 2016 Haha that actually cheered me up a bit lol. Been working on it most of the day the relay is switching correctly even changed it in case it didn't like the load that the pump puts on it.
stants Posted September 27, 2016 Posted September 27, 2016 Have you tried a new pump ? Or is your alarm cutting power to the pump ? Sent from my SM-G930F using Tapatalk 1
JamesJDMwagon Posted September 27, 2016 Author Posted September 27, 2016 Yes popped the old one in. bench tested the other both work great so put it all back together. I would of thought the alarm would cut all the power but don't know enough about them. It's strange to say the least. When the engine is cranking I only get one volt at the pump. The relay is cycling 12volts so that works. Really stumped on this one
savage bulldogs Posted September 27, 2016 Posted September 27, 2016 Have you checked the relay out put towards the pump ? (Break in the wire ? ) Cam n crank sensor loose or corroded plugs ? As it will turn over but not start if their not plugged in . Although I was fairly sure that removing the cam or crank sensor cuts spark not fuel (might be worth checking though ) 1
JamesJDMwagon Posted September 27, 2016 Author Posted September 27, 2016 Yes check the relay it's all good it's got to be a problem between the relay and pump. I'm going to start tracing the wires tonight see where the 12v ends and 1.2v starts hopefully I can find it. Maybe the alarm intercepts it?! Who knows. the only ecu code I've got stored is temp sensor. But I'll check the maybe give them love with contact cleaner. might even wire the pump on a switch until I find the problem
stants Posted September 27, 2016 Posted September 27, 2016 I take it being an import it's an aftermarket alarm ? Sent from my SM-G930F using Tapatalk 1
JamesJDMwagon Posted September 27, 2016 Author Posted September 27, 2016 Correct think it's a selica? Or something similar
stants Posted September 27, 2016 Posted September 27, 2016 Best off getting key fob or manual and googleing the alarm will be able to get some wiring diagrams of where they've made the cuts into the loom Sent from my SM-G930F using Tapatalk 1
JamesJDMwagon Posted September 27, 2016 Author Posted September 27, 2016 That's a great idea i'll look into it thanks
JamesJDMwagon Posted September 27, 2016 Author Posted September 27, 2016 This is the alarm can't find any useful information about it
stants Posted September 27, 2016 Posted September 27, 2016 What does fob look like ? Sent from my SM-G930F using Tapatalk
JamesJDMwagon Posted September 28, 2016 Author Posted September 28, 2016 Thanks for the input guys 😊 It's all fixed now couldn't be happier. Turns out the alarm intercepts the fuel feed and the board that controls the pump in the alarm has gone bad so it was bipassed but leaving the alarm spliced in so it doesn't know what's going on. Had to cut open the loom under the carpet find where the alarm bridges the live. 2
savage bulldogs Posted September 28, 2016 Posted September 28, 2016 Glad it's up n running again [emoji41] I think my alarm was about £220 fitted ,Thatcham, hidden switch and a built in turbo timer . He's a mobile fitter but I think he only does Essex n Suffolk areas 1
JamesJDMwagon Posted September 28, 2016 Author Posted September 28, 2016 I was thinking of putting a new one in that's a good price. I'd imagine it would be more hassle having to fit a new one to mine as the old one would need removing and my god it's a mess haha. But everything works now just the alarm won't cut fuel but still cuts everything else. Mines a cat 1 thatchan approved system. Now it's time to test her out 😜
stants Posted September 28, 2016 Posted September 28, 2016 A good fitter will strip the old one out foc while putting the new one in, worth mailing a couple of companies and seeing what they offer Sent from my SM-G930F using Tapatalk 1
savage bulldogs Posted September 28, 2016 Posted September 28, 2016 Mine wouldn't let me in without the alarm going off , let alone start the dam thing . I was booked in at a airport car park to go away in 2 days . He had the alarm siren off and car started within a minute even without a working fob . Then fitted the new one in a couple of hours [emoji41] 1
JamesJDMwagon Posted September 28, 2016 Author Posted September 28, 2016 Looks like I will be having a new alarm then! Don't want this one causing any more problems. dint want to be tied home I. Shame again haha. It was only off the road for two days and I missed her.
