Possible blown turbo
Hello can anybody help me I was driving along today went to accelerate and the turbo sounded different like a hissing noise and won't boost also it tries to cut out when coming to a stop with clutch in not smoking yet but drives like rubbish any ideas how to find out without spending money no lights on dash nothing
blew a vac pipe?
Had a quick look can't see any pipes split or cracked anywhere
Would that make car cut out when coming to stop
It could do if you lose enough vac pressure. Must be a mighty leak. Have the car running and listen from under the bonnet. Try to give it a little rev to increase pressure making a leak more obvious.
You have a lot of pipes to check takes a good hour to check them all and he inlet cracks when under pressuec
