http://lateralperformance.co.uk/product.php/122/25/injector_adapter_kit_to_fit_phase_two_injectors__into_phase_one__93__98__rails
Just wondered if anyone has any experience or knowledge with these? Pricing up injectors it seems a few hundred £'s cheaper to get these Adaptors and a set of high flow modified phase 2 injectors than it is to buy a set that will fit the phase 1/1.5 rails. But not 100% sure I can trust these?
I had a set of these but from scooby clinic as they were closed when I came to order worked perfect just make sure all seals seat properly now upgraded to cdf high flow rails if you have any problems I'll do my best to help
I bought these a few months ago from lateral to go with a set of yellow 440's, i've not fitted them yet though as can't get for a remap till later on in the year but they look the part and the service was spot on and they arrived next day so really can't complain 😁
Thanks guys, spoke to a mechanic I always use today about them too and he says they're spot on so going to get them ordered.
Cheers!
I run a set of lateral phase adapters to fit my nismo 550's .
What's your target power ? As yellow 440's will max @ about 350hp .
I've got a sc36 at minute but will eventually get a md321 for about 400. Was told on last map I could do with some bigger injectors as they're holding it back even with the mods it's currently got
