Impreza Newage OEM & Aftermarket Parts 2000-2007
All parts taken off a 55 plate blobeye and are compatible with all newage imprezas 2000-2007, some parts may retro fit onto older models but research may be needed before attempting this.
Will post within the UK or collection is welcome from York or can meet at leeds, harrogate etc. if it's within a reasonable distance
Payments via paypal, bank transfer or cash on collection
GFB Respons TMS Hybrid Blow off valve like new not been on the car much as not a vta bov fan and going back to the standard recirc before a new mapping, box and all instructions included. SOLD
oem mid section welded to aftermarket 3.5" baffled rollback tip backbox, nice fitment without drone on long distance and makes a nice classic burble  £50 collected only
Exhaust Headers with sensor £50 posted or £30 collected
Cat down pipe and Cat up pipe with both sensors £75 posted or £50 collected
18403338_10155049467062631_5978146542611333751_n1.thumb.jpg.93a9ac27b6733a769d1e766d0f969e04.jpg
TD04 Turbo in great working order, all threads and studs in tact and no play in the shaft, no leaks, or any kind of damage. Was always run on stock WRX map so never been stressed SOLD
TGV inlet manifold with fuel rails (may strip it down and paint it yet for resale) £65 posted or £45 collected
59304cad06c41_18402850_10155050970437631_5764044927901255876_n(1).thumb.jpg.ba9761e6a0aac6186a069823c0b738f7.jpg
Denso 440cc top feed fuel injectors in perfect working order, nice and clean with seals SOLD
STI Denso 3 port boost solenoid £30
WRX Denso 2 port boost solenoid £15
Oem fuel pump in perfect working order £20
Full timing belt kit 15k miles old in very good condition, only taken off as needed a new thermostat seal so decided to redo it all at the same time before remapping.
£40
Water pump 15k miles old in perfect working order only replaced as thermostat seal was going
£15
Washer bottle acrylic painted black with red rising sun subaru vinyl
£30
Freshly painted pair of red radiator stay mounts £15
12705204_10153798019637631_142523571936636876_n.thumb.jpg.836ae62a56304261af51f17b82356c60.jpg
Lower black bumper grille x3 available £10 each, requires 6 tie wraps to fit or can silicone it or use screws
IMG_0300.JPG.33c90be3855efd09a15365ead3f935cd.thumb.JPG.55c7aa55c0cf9dd6462bca85d8e582d1.JPGIMG_0299.JPG.64221b00e13f414833716771725dcea7.thumb.JPG.ba79a15ab0804d52426bb07474e8d421.JPG
Oem intake induction pipe £20
STI silicone intercooler to turbo pipe £15
Airbox pipe £10
Re-circulation blow off valve rubber hose £10
Various other hoses available...
Updated plastic headertanks secondary radiator hose blanked off  £15
Oem Radiator in good working condition no leaks £20
Black WRX Sideskirts in good condition £50
17264835_10154876570522631_8530427638461349982_n.thumb.jpg.6443669aaa2613133b7d42d869ec8b85.jpg17201403_10154876570527631_4126551538650304220_n.thumb.jpg.835880eb69e39c9423987addd1616718.jpg
Black 32j low riser oem WRX wing in good condition no paint chips £25
12744129_10153809056882631_4465776307506113783_n.jpg.d98d57d430c098a12e13901a303de238.jpg1491660_10153809056887631_1033099811700313390_n.jpg.5c3250474a5d1a4a769ec2900edcc706.jpg
Subaru oem double din stereo in perfect working order £20
12733614_10153809056962631_4795865707405697499_n.jpg.84898306c2cfe7b0475ef57edc01e85b.jpg
Subaru oem clock £10
17758570_10154940842172631_1122246151958328001_o.thumb.jpg.811c82f87cce4c5c502a61f2949e0cf1.jpg
Hello mate is that dump valve the adjustable one ?
If its the same as the gfb hybrid i had there a really really good dv i was gutted i couldnt keep mine when i changed to a tmic
@kershaw-330s @Rps
Yeah you can fine tune the venting ratio and spring tension it's a great piece of kit for vta lovers
I just had it setup as a recirc valve just like the oem valve all the time and only had it vta whooshing at the odd car meet so would rather put the money towards my next plans for my car.
Wanna sell your wheels :) il let u have mine in px
I might play around with the idea of swapping wheels to something else next year when I start on my planned handling build that I want to do
Gimmie a shout if u do wanna sell mate il have first refusal 😊
List updated and postage prices or collection for larger items added
Do you still have the 2 port boost solenoid
Yep still got it
Where abouts are you or how much posted
I'm up north, postage would be £3 extra
How much for one of the black lower grilles posted?
Unfortunately I got quoted £13 as the best price from all postal services because of the length of it so because the postage is high I'm asking £20 posted
